TwinTurbo.NET: Nissan 300ZX forum - Probably tie rod, maybe ball joint or lower or upper
just4kinks
on March 19, 2010 at 10:25 AM
What is worn for this to happen:
posted by yobobrox
on March 19, 2010 at 10:17 AM
control arm bushings. Check each part independently for play.
yobobrox
10:17:04 03/19/10
Probably tie rod, maybe ball joint or lower or upper -
just4kinks
10:25:38 03/19/10
Thanks; I don't know a ton about suspension/steering parts.
yobobrox
10:43:58 03/19/10
there are also inner tie rods that are under the rack boots (n/m)
aliaZ
11:42:32 03/19/10
Thnx. I just found some diy videos that explain about that.
yobobrox
11:48:16 03/19/10
I believe so
aliaZ
11:49:25 03/19/10
Re: What is worn for this to happen:
ttz'in (NorCal)
11:01:53 03/19/10
<--- Technical (n/m)
zfreak(Dallas)
11:03:24 03/19/10
Tension rod bushing ok. Any leaking? (n/m)
MrPulldown
11:08:26 03/19/10
Er. I have a small power steering leak.
yobobrox
11:10:22 03/19/10
He means leak in the fluid-filled TR bushings. (n/m)
BradX (UF)
11:12:56 03/19/10
Ah. Ok, I'll check those, too (n/m)
yobobrox
11:33:53 03/19/10
